Western Members CA, AZ, NV, UT, CO, NM, HI
fuel pump
Old Aug 18, 2008 | 08:00 PM
01black's Avatar
Default fuel pump
anyone got a 255 lph for sale cheap? need to get my car back on the road asap...wanted to replace my burnt racetronix with a new one but i cant wait that long...
mike
nevrlift@hotmail.com
Old Aug 19, 2008 | 12:24 AM
Ryne @ CMS's Avatar
LS1TECH Sponsor
racetronix burned out? no ****? i think i have an extra racetronix in stock i will sell it to you at my cost bro
Old Aug 19, 2008 | 01:22 AM
Almostryan3's Avatar
mike
What happened to it? Do you know? I haven't seen many go out because of the pump failure itself. Did you install it yourself or was it already installed, maybe it had a bad connection somewhere.
Old Aug 19, 2008 | 01:27 AM
Datzneat's Avatar
Run the car with less than a quarter of a tank much?
Old Aug 19, 2008 | 01:30 AM
Thats shouldn't matter seeing as how our cars have a bucket the fuel pump sits in so its always submerged. Hell I use to race a full day of racing with the gas needle reading under E
Old Aug 19, 2008 | 02:08 AM
ss.slp.ls1's Avatar
Yeah, but if you run it completely dry, you'll be on the market for a new pump.
Old Aug 19, 2008 | 02:18 AM
Yeah but he said under a 1/4. Like I said full day of racing under E many times and I never had a problem.
Old Aug 19, 2008 | 03:01 AM
SSMOKIN_Y2KSS's Avatar
generally speaking under low fuel 1/8th or lower you can damage you fuel pump but its not very likely. but what you very well can do is jam the fuel valve safety ball at the bottom of the fill tube. and after it gets jammed in there your actually producing vacuum in there after awhile that could burn out the pump. or you wont be able to fill the tank when u get to the station..u try to pump fuel into it and it shoots back at you..pretty funny to watch i might add..
Old Aug 19, 2008 | 03:33 AM
So a ball clogs up the fill tube. Which creates a vacuum from the fuel pump even though its submerged in fuel and it will burn up because of this vacuum? Am I missing something....
Old Aug 19, 2008 | 04:38 AM
Datzneat's Avatar
generally speaking under low fuel 1/8th or lower you can damage you fuel pump but its not very likely. but what you very well can do is jam the fuel valve safety ball at the bottom of the fill tube. and after it gets jammed in there your actually producing vacuum in there after awhile that could burn out the pump. or you wont be able to fill the tank when u get to the station..u try to pump fuel into it and it shoots back at you..pretty funny to watch i might add..Happened to you eh? lol
What I was implying... Thanks. Didn't think I had to go into so much detail. The gas is what cools the pump also so repeatedly running the tank to dry can and will cause the pump to burn up. Seen it a few times. I'm putting in dual walboro 440s in right now so no more running below quarter tank for me.
Old Aug 19, 2008 | 11:38 AM
01black's Avatar
cool appreciate all the input...but does anyone have one they wanna part with?
Old Aug 19, 2008 | 11:39 AM
01black's Avatar
oh **** i didnt see that post...ill pm ya
Old Aug 19, 2008 | 12:13 PM
it works very similar to a bilge pump in a boat have u never seen how these operate..or do i have to draw a diagram on how i might be able to suck in air while driving on an 1/8th or lower tank...cause if need be this can be arranged...
imo stupid arguement and off topic
Old Aug 19, 2008 | 01:26 PM
Nope never seen how a boat fuel tank operates. I'm just saying what creates a vacuum? As long as the pump is submerged in fuel it shouldn't matter. And in all cases wouldn't the fuel fill tube be plugged because of the cap being on?
Old Aug 19, 2008 | 01:59 PM
ss.slp.ls1's Avatar
The side discussion doesn't really matter...simple point is that running extremely low or dry i.e. partially or completely emptying the bucket can potentially damage your fuel pump.
Old Aug 19, 2008 | 02:02 PM
Thread did get a little off but I think he found one already so its ok
Old Aug 19, 2008 | 02:46 PM
01black's Avatar
im a happy camper...ryne came through in a pinch!!!
