Western Members CA, AZ, NV, UT, CO, NM, HI
Throwing Codes!!
Old Sep 3, 2008 | 11:12 PM
L3THAL_Z28's Avatar
Exclamation Throwing Codes!!
Car threw a P0332 code...scanner said the follwing:
Knock Sensor 2
Circuit Low Input
(Bank 2)
I basically just have full exhaust and intake with some suspension stuff on my 2000 Z28 M6...just want to know what I have to do to get this taken care of. I need a tune don't i?
Old Sep 4, 2008 | 12:49 AM
ss.slp.ls1's Avatar
Knock Sensor 2
Circuit Low Input
(Bank 2)
You have to remove your intake mani and clean/inspect/replace the knock sensors and knock sensor wire harness.
Old Sep 4, 2008 | 01:22 AM
TA-Swede's Avatar
x2
On the up-side, since that sensor probably was failing for a while, you're likely to pick up a few degrees of timing by replacing it.
Old Sep 4, 2008 | 10:39 AM
L3THAL_Z28's Avatar
cool, thanks guys. Is there a write up for this? I've only gone as far as removing the valve covers and would have no idea what Im looking for thanx
Old Sep 4, 2008 | 11:31 AM
ss.slp.ls1's Avatar
Follow this for the removal of the intake manifold:
http://www.ls1howto.com/index.php?article=5
Once it's off, simply remove and replace the knock sensors. Use two screw drivers or a pair of pliers to gently squeeze on the wide ends of the gray connectors on the knock sensors. IIRC it should be a 7/8 socket to unscrew them. Check the wiring thoroughly.
Here's a picture:
Good luck with it.
Old Sep 4, 2008 | 12:29 PM
L3THAL_Z28's Avatar
cool thanx bro...I'll be sure to hit u up if I run into any trouble
Old Sep 4, 2008 | 12:30 PM
hlaalu's Avatar
hmm ive had that code thrown too, any chance it could lead to an oil leak? my car is leaking pretty bad
Old Sep 4, 2008 | 12:35 PM
ss.slp.ls1's Avatar
No problem man. Happy to help.
Unfortunately, no.
Old Sep 4, 2008 | 12:51 PM
hlaalu's Avatar
damn, oh hey i just found out im 99% sure im coming home next weekend
Old Sep 4, 2008 | 12:53 PM
ss.slp.ls1's Avatar
Hit me up when you're back in town. Are you bringing the Hummer engine with you?
Old Sep 4, 2008 | 01:05 PM
hlaalu's Avatar
lol i wish. that thing was gone we didnt even get to loot it and it was only a 4cyl how gay is that for a hummer... no wonder it flipped
Old Sep 4, 2008 | 01:42 PM
ss.slp.ls1's Avatar
I'm pretty sure it was a 6 cyl, it would still be fun to put that in a buggy.
Old Sep 4, 2008 | 02:18 PM
hlaalu's Avatar
nope had to have been a 4, just had one exhaust manifold
Old Sep 4, 2008 | 02:21 PM
ss.slp.ls1's Avatar
We're both wrong, its a 3.7 liter inline 5.
Old Sep 4, 2008 | 02:25 PM
hlaalu's Avatar
wtf ive never heard of such a thing haha who would want that haha
Old Sep 4, 2008 | 02:26 PM
ss.slp.ls1's Avatar
LOL, I think thats the same thing or similar to what comes in the Colorado.
Old Sep 4, 2008 | 02:40 PM
hlaalu's Avatar
and hummer is suppose to be all big and bad *** too
Old Sep 4, 2008 | 02:51 PM
ReFtheMC's Avatar
Dont worry george i gotta remove my intake to. I just dont want to because i dont have a torque wrench, hahaha
Old Sep 4, 2008 | 02:55 PM
hlaalu's Avatar
what do knock sensors do anyways?
Old Sep 4, 2008 | 03:12 PM
ss.slp.ls1's Avatar
You don't need one, the intake manifold is torqued to 89 in.lbs ~ 7 ft.lbs ~ hand tight. It doesn't take much to get the plastic gaskets to seal.
From what I know, they sense vibrations in the motor (knocking) and retard timing to compensate.
