1996 z28
Old Dec 20, 2008 | 09:52 AM
efirdj's Avatar
Unhappy 1996 z28
I am thinking about selling my baby. We really need the money, but i dont know what I should be asking. I know what I paid for it, I know how much money got put in to it. Please give any input you can if you think it might help.
thanks in advance for the help.
some pictures and details can be found HERE <---click
1996 Camaro Z28. 6-Speed. Just over 88,000 miles. T-tops. Power Windows/locks/mirrors, Bose sound system. her best run put her at a 12.9 @ 108 in the 1/4. someone that can drive better than i can could probably get down to the mid-12's.
POWER TRAIN
Underdrive Pulley Kit
58mm BBK Throttle Body
8.5 MSD Plug Wires
Royal Purple Engine Oil Racing-21
160* Thermostat
LT4 Intake Manifold (ported)
LT4 Heads
LT4 Hot Cam
LT4 Knock Module
LT4 Extreme Duty Timing Chain
1.6:1 Comp Gold Roller Rockers
Dual Valve Springs
Hardened Steel Push Rods
Accel 30# Injectors
Meiziere Electric Water Pump
RaceTronics 255 Fuel Pump
Holley Fuel Pressure Regulator
Granetelli MAF
A/C Idler Pulley with A/C delete
Moroso Cold Air Intake
Vortec Intake Elbow
MSD Ignition Coil
New Optima Red Top Battery (July 25)
DRIVE TRAIN
B&M Ripper Shifter
Hurst "T-Command" Shift Handle w/ built-in Switch for Line Lock
Hurst Roll Control
McLeod Twin Plate Clutch
Billet Steel Flywheel
Strange 12 Bolt Rear w/ Strang Heavy Duty LSD (4.11 gears and 31 spline axles)
Royal Purple Syncromax MTF
Royal Purple Max Gear Oil
Spohn "Extreme Duty" Driveshaft
EXHAUST
Super Comp Hooker Headers full-length(Jet-Hot Coated)
Mufflex Custom "Y" Pipe
Dual Hi-Flo Cats
Mufflex 4" Over Axle Exhaust
Cosmetic, Body, Suspension
Wings West W Type Body Kit
"Stinger" Hood
BMR Tube Lower Control Arms
BMR LCA Relocation Brackets
BMR Subframe Connectors
ZR1 Grand Sport Wheels 17x9.5 & 17x11
Rear "CAMARO" reflective black vinyl inlay
3rd Brake Light Overlay (Z28)
Super Bright red LED's for Instrument Cluster
White Face Guage Overlay
Old Dec 20, 2008 | 05:44 PM
NC01TA's Avatar
You have one heck of a car there but you are going to get killed financially. You have a ton into it that you will never get back. I'm sure you have read numerous posts about rarely getting half your money back when it comes to mods. You can only hope to get half back and even that may be a real long shot in this bad seller's market. I hope you can keep it. If not, good luck!
Old Dec 24, 2008 | 07:51 PM
efirdj's Avatar
yeah, i knew half would be a stretch. but i have looked into various posts all over the web trying to find some way to price a modded car. but ive come up short on any really helpful info due to today's economy. ive got over $15k in mods. performance and visual. and kbb has a value of about $5k. so using the 1/2 of mods value, plus the value of the car, that leaves me a total of $12k. but i know $12k is pretty high, but cant figure out what a fair asking price should be.
