98 Trans Am?
Its a 98 Trans am with 98k miles
After i got it the engine let out and I replaced it with a motor out of an 01
WS6 with 50k miles on it
Motor:
TSP lid
FAST 90 Nick Williams 90mm TB
Futural F13 cam
Absolute Speed stage 2 heads
Kooks 1 7/8 w/ORY
Hooker catback with SLP tips
Trans:
Circle D built MVB TH350
Circle D 3800 stall
B&M Pro Ratchet shifter
Suspension:
BMR K member
BMR subframe connectors
BMR Torque arm
BMR lower control arms
BMR adjustable panhard rod
Hotchkis lowering springs
Rearend:
10 bolt 3.42 gears out of 02 ws6 with TA girdle
Misc:
SVO 42 lb injectors
Walbro 255 pump
Raptor shift light mounted in the defrost in pillar
Steel driveshaft
Before the th350 and kooks with 3.73 gears it made 427/421 stall unlocked
with the th350 and kooks made 407/380
when the car was cam only and bolt on's it went consisten 11.57
since the heads, th350, and old FLP's havent ran 1/4 but its gone 7.27 in 1/8
now with the kooks and retune should be knockin on the door of 10's easily.
I still have the built 4L60e that was in it and im just wondering how much you guys think i could get for it as is, because swapping it back would be a pain.... I miss having a fun car to drive so if i could sell it and pick up something local that would be great.
here are some pics:
what do you guys think????
