2001 ws-6
Old Jul 16, 2009 | 11:18 AM
thechef's Avatar
Moderator
Default 2001 ws-6
SLP LID w/ K&N Filter
ESP ported tb
ESP ported MAF
ASP Pulley
ESP Cam 224/228 569/571 112 lsa 443 rwhp conservative tune
Edelbrock 205 heads
Edelbrock 1 3/4-1 7/8 stepped headers
Edelbrock y pipe
Magnaflow catback
Spec 3+ clutch
Hurst Billet Shifter w/ Lou's Short stick
Hurst Line Lock
Aftermarket Steel Driveshaft 1350 yolks
BMR K frame
BMR Upper and Lower A Arms
Hal Qa1 Shocks and Springs Front#325 spring
Hal Qa1 Rear Shocks
BMR Rod End ADJ PHB
ESP Rod End ADJ LCA
SLP sub frame connectors
SLP drive shaft loop
LCA Relocation brackets
MOSER 9 in rear
Strange "S" Alum center section 3:90 gear 1350 yolk
Tru Trac Posi
31 Spline axles
long aftermarket studs
NX EFI Single Nozle kit
MSD window switch
NX TPS switch
NOS Purge
Dyno tune heater
Dyno tune bottle mount (spare tire well)
Dyno Tune Digital Guages (NOS& Fuel) on A pillar
NX kit has only been used 2 times on the street, car just smokes the tires go figure lol...
Aftermarket Stereo Alpine
Sub kicker
AMP 350w memphis
Black 17x9.5 and 18x10.5 Black zo6 motorsport wheels
Paint is pretty good just repainted the nose this past winter and paint matches perfect
car has been in GM High Tech and on PINKS ALL Out
will come with slicks and skinnies Convo Pros, car has run in the 11's with a NOS tune but never run with the spray, and the car has only been sprayed 2x on the street
shortblock has 99k on it as does the tranny, but all work great and run strong
would also possibly consider a trade for something interesting
