98 Turbo Z28
Old Aug 30, 2010 | 11:06 PM
importkiller_SS's Avatar
Default 98 Turbo Z28
1998 Turbo Camaro Z28 w/ 107,000 miles
no hvac/heat
put down 540rwhp/480tq on 10psi
Think its possible that someone with a stock c5zo6 might want to trade?!? or just even c5?
Engine:
stock 107k LS1 shortblock
233/239 .598/.603" 113lsa
Low mileage 317 6.0L heads
Fast 78 intake
meillings high volume oil pump
jwis c5r timing chain
Summit fuel rails
Aeromotive FPR
Motron 60's
SPOHN Solid motor mounts
Brand new w/ 1 yr warranty Borg Warner S300 67.5mm turbo
Suspension:
UMI Adj body mount Tq arm
UMI Lower control arms
BMR Adj panhard bar
Spohn relocation brackets
Hotchkiss SFC
SPOHN 32mm front sway bar/25mm rear sway bar
9" backbraced, 31 spline tru-trac, 3.25 gears, solid adj "crush" tube
BMR STB
Wolfe 6pt MS roll bar
Trans:
Built 4l60e performance rebuild from pro-built
Old Sep 1, 2010 | 11:52 AM
I was thinkin it could go for 8500-9000$
