2002 Formula
Old Jul 31, 2011 | 08:13 PM
chevbon's Avatar
Default 2002 Formula
02 formula 113k kbb is 7k in good shape. Has 19" wheels, needs a rear tire. Throwout bearing makes a noise at idle (anyone know what this entails?), needs battery. Whats it worth?
Old Aug 1, 2011 | 05:37 PM
NC01TA's Avatar
$7,000 sounds OK at face value without knowing about other things. The battery and tire (or two rear tires) are just maintenance and upkeep so no big deal if everything else checks out. The big ?? is indeed the bearing. I have no idea but once you find out an accurate estimate, it should be subtracted from the price, or at least split 50/50 once brought to the seller's attention.
