Whats it worth? My heavily modified street/strip 2000 TA
Here is the mods list. I don't know what the car is worth but I prob. have close to 35-40k into the car not including it. So What is it worth?
Parts run down:
Car:
-2000 Trans Am with 24,000 miles on the body. Onyx black with a Glasstek hood.
-The rest of the exterior is stock with nothing else done to it.
-15x4 Prostars in the front with MT runners (new)
-15x10 Prostars in the rear with Hoosier 28x10 DOT slicks (almost brand new less than 10 miles on them).
Interior:
-Full leather interior, it's all stock. The seats look brand new since there is so little miles on the car. Stock Radio, stock speakers, stock carpet, etc...
-8 Point Wolfe Racecraft Roll Cage.
-All Autometer and AEM gauges.
Motor:
-Iron Block LQ9 6.0l built by HKE, it is now a 408.
-Eagle Forged Rods.
-Custom Wiseco -32cc Pistons with coated skirts and tops.
-Hell Fire Rings.
-Eagle Forged Crank.
-All ARP equipment in the block.
-TFS 225 Heads done over by Tony over at AFR.
-LS9 Gaskets.
-Harland Sharp Rockers, Comp springs, pushrods, valves, etc...
-I'm probably missing some things.
Trans:
-Rossler 4l80e transmission reworked.
-With Rossler Tree Breaker 4L80E Ross-Lock
-Moroso Deep Pan.
-Pro Torque 1600hp converter that has a stall speed set at 3800.
-Line Lock, Stall Lock, all installed.
Suspension:
-QA1 Coilovers and struts up front.
-Strange 300lb drag shocks in the rear.
-All New BMR bushings
-Spohn LCA's
-Spohn TQ arm.
-Spohn Panhard Bars.
-BMR Turbo K-member up front.
-BMR Engine mounts
-I think I am def. forgetting some parts here
Turbo Kit:
-S91 turbo that was just redone by Forced Inductions (balanced, checked and spun).
-All powder coated cold side
-All coated hot side
-31x24x4 Intercooler
-Dual Tial 44mm WG's
-Turbosmart 60mm BOV.
-It has a 4" Electric cut out.
-AMS 500 Boost Control
-I made the kit to look like it was almost stock for the sleeper look. It has a 5" DP going to a 4" electric cut out than it merges with a Magnaflow exhaust for the total street look and sound.
-This is all brand new with 0 miles on it.
Fuel System:
-NastyPerformance Custom Race fuel tank with gauge sender
-MagnaFuel 4303 fuel pump (Great street pump)
-NastyPerformance Billet fuel rails
-NastyPerformance Billet Y-block
-Fuelabs billet fuel pressure regulator w/boost ref. -Fuelabs billet pre stainless steel fuel filter
-Fuelabs billet post stainless steel fuel filter
-Aeroquip -10 braided stainless feed fuel line
-Aeroquip -8 braided stainless return fuel line
-NastyPerformance hotwire kit
-FIC 125LB/hr High Impedance Injectors.
Rear End:
-Moser Ford 9" in the rear
-3.73 Gear Set
-Strange Center Section
-Steel Drive Shaft
-Etc...
Everything that I have listed has less than 500 actual miles on it. So All of this stuff is almost brand new. I am sure I am missing a few things but this is kind of the narrowed down list.
This car makes 1xxx HP.
Parts run down:
Car:
Interior:
Motor:
-Eagle Forged Rods.
-Hell Fire Rings.
-LS9 Gaskets.
Trans:
-Moroso Deep Pan.
Suspension:
-Spohn LCA's
-Spohn TQ arm.
-BMR Engine mounts
Turbo Kit:
Fuel System:
Rear End:
-3.73 Gear Set
-Steel Drive Shaft
-Etc...
The classic question. It is worth every penny you put into it, all $40,000 of it. Now if you want to know what you can sell it for, good luck! Really decent low mileage heavily modded cars can't be sold for even $15,000 in many instances. Many posts in this section over the past few months detail the lack of decent money for these type cars. It is extremely heartbreaking to see this but the buying market just isn't there. Younger people would LOVE your car but they have no money. It's that simple. Are there exceptions? Of course, but don't expect it.
