street/strip 98 trans am worth?
i have a 1998 trans am with 163,000 on the body. 3 years ago i bought a motor out of a wrecked 2000 ss camaro, and had a local ls1 guru flycut pistons and instal one of his custom grind cams. i had the stock heads ported and polished put 921 comp cam springs the larger 2.02 manley valves titanium retainers and seats. fast 90/90 setup, aftermarket lid, 30 lbs injectors, pacesetter headers, b&b exhaust. xtreme level 2 transmission with circle d 3800 converter, tci deep trans pan, and b&m trans cooler. moser 12 bolt rear, bmr torque arm, pan hard bar, and solid bushing control arms. comp eng. drag shocks. weld drag stars 15x3.5 fronts rear 16x8 mickey thompson drag radials. also have a set of y2k corvette wheels 17x8 front with tires 18x9.5 rear no tires. baer drilled and slotted rotors front and rear with hawk brake pads all the way around. racetronix fuel pump installed by rpm and tuned by rpm made 430 to the wheels best e.t. 11.47.
The bad. paint and body in fair cindtion for 163,000 miles. fuel gauge does not work. no rear seats.
please let me know what you guys think it is worth
thank you
Rich
thank you
Rich
