can someone help me??
2002 Camaro Z28
49,652 miles black on black hard top
Engine:
stock short block
LG G5X4 cam specs can be given by lg
comp cams lifters
comp cams behive valve springs
comp cams locks
comp cams hardened push rods
factory LS6 intake and throttle body
smooth bellow tube
slp lid with ram air upper box
ford motorsports green top 42lb injectors
american race headers stainless steel long tube headers and off road y pipe
hooker cat back with black powder coated quad tips
160 degree thermostat
Transmission
t 56 6speed with factory hurst shifter
monster stage 4 clutch
adjustable master cylinder
new slave cylinder
Rear
moser 12bolt
4.10 gears
31 splines axles with factory wheel studs
suspension
umi 35mm front sway bar
umi 22mm rear sway bar
umi adjustable torque arm
umi on car adjustable panhard bar
umi double adjustable lower control arms
relocation brackets welded to rear
umi weld in sub frame connectors
rims
oem factory wheels (snowflake wheels) fronts and rears with drag radials
oem factory zo6 wheels with bfg radials 275/45/17 & 295/35/18
