1998 z28 m6
1998 Z28 Silver, t top, M6, 86k miles, dark grey leather, power windows/locks, cd/monsoon system Exterior: VFN Sunoco cowl hood, chrome ZR-1s (9.5 fronts/11 rears), Nitto NT05s (275/315), side emblems removed, SLP bowtie grill
Engine: stock bottem end with Katech rod bolts, flycut pistons. TEA stg2 LS6 heads, Pat G custom cam (232/234;.612/.592 112+2). FAST 90 ported by Tony Mamo@AFR, Nick Williams tb, 30lb SVO injectors, QTP lts and ory, Magnaflow catback with Corsa clone tips, Fasttoys 85mm lid, 85mm maf.
Transmission/Rear: Transmission built by Tick Performance (stage 2 iirc) Textralia OZ700, Tick adj. master. Moser 9" w/ Detroit Tru Trac, 4.30 gears, 3 channel abs, powder coated. Custom aluminum drive shaft.
Suspension: Koni DAs, H&R springs 650f/200r, Strano sways front and rear, BMR lower control arms and torque arm
446rwhp/394rwtq thru the 9". Ran 7.67@96.xx with 1.76 60ft on Nitto drs with full weight and the current "handling" suspension setup
Think that's it, so what do y'all think?
