2000 z28 turbo
2000 z28 turbo
Has just under 70k on chassis is silver and black outside is 9/10 condition. Interior is 7/10 has a Corbeau racing seat on driver side, has a weld in 6-point cage, no rear seat. Drivetrain. Consist of a 5.3 with 317 heads dual springs a mild cam equilvalent to a ls9 cam, hardened pushrods and tru union bearing upgrade. Has a huron speed custom front mount turbo kit with a t7875 turbo 46mm wastegate, 4" intercooler, griffin radiator stood up, has a built 4l60e trans, has all spohn tubular suspension front to back, umi k-member, strange adjustable shocks, and last a ford 9" in the rear with moser 31 spline axles, has weld in subframe connectors, fuel system is dual walbros in tank 105lb injectors return style with 1/1 adjustable regulator also is wired for nitrous and I have run 10.3 on a 100 shot and 12psi of boost also has zr1 replicas 17x9 in front and 17x11 in rear with nitto 555r drag radials. I'm sure there more but you can get a good idea what it has. I'm lookin to sell it and would like to have a general idea what it would be worth? I'm lookin to get money towards a c6 vette.
