1986 LS-3 Ford LTD WIW?
I have a 1986 Ford LTD Brougham original 63000 mile car that I've done the following swap to:
Engine:
2008 6.2L
BTR Dble springs
Tick Hyd cam
Hardened pushrods
Caddy lifters
90mm T.b.
120# Holley Injectors
1-7/8 to 3-1/2" collector long tubes
3" full exhaust w/ X-pipe and stainless straight through mufflers
AEM 320 Lph pump
CTS-V oil pan
Transmission:
Built 4L80E
Shift kit
PTC billet single disc lockup converter
B&M Bandit shifter
3' Chromo driveshaft
Front suspension:
SN-95 spindles
13" Cobra brakes w/ Hawk pads
New struts
Larger front sway bar
Power steering
Rear Suspension:
8.8
31-spline Moser axles
Aftermarket Carrier
SN-95 disc brakes
Summit Upper and Lowers
Rear sway bar
3.08 gears (2400 rpm @ 80 mph)
17x8 Bullet wheels w/ brand new 245/45/17 tires
EFI:
Holley Dominator EFI w/ touch screen dash.
It is a very clean car with blue cloth interior split bench seat. The ac does need to have lines made to connect the condenser to the evaporator.
Any thoughts on what it'd be worth?
Engine:
2008 6.2L
BTR Dble springs
Tick Hyd cam
Hardened pushrods
Caddy lifters
90mm T.b.
AEM 320 Lph pump
CTS-V oil pan
Transmission:
Built 4L80E
Shift kit
B&M Bandit shifter
Front suspension:
SN-95 spindles
New struts
Power steering
Rear Suspension:
8.8
Aftermarket Carrier
SN-95 disc brakes
Rear sway bar
EFI:
