98 z28 hardtop built lq9
whats it worth I have a 98 z28 hardtop with a brand new built lq9 30 over with new forged mahle flat top pistons eagle forged rods 600 lift cam all arp hardware rod bolts main and head bolts new katech timing chain and gears new melling ported oil pump 317 heads mild port work pace long tude 1 7/8 headers new hi torque starter ls1 intake with 90mm billet throttle body new 60lb injectors and aftermarket fuel rails and regulator msd plug wires new 3800 torque converter new built 4l60e trans good for 900hp front qa1 coil overs adjustable shocks umi adjustable torque arm solid rrear lower control arms and panhard arm with grease fittings drag bags in both rear coils plastic gas tank out of later model camaro 255 walbro pump ,new powrer rack new front and rear black race stars 10x15 rears with 275-60 mt drag radials and 15x4 front mt radial tires ,drilled dics rotors on front glass cowl hood and stock hood all removed parts go with car all under dash ac still in car inside clean stock and origional dash pad cracked from sun nuce straight body has plasti dip white on it 99k origional miles auto meter pillar gauges oil and water have receipts for engine build of 7500 and trans build of 2200 would consider 10k whats it worth??
