2000 Camaro Z/28 H/C/I
2000 Chevrolet Camaro Z/28
Navy blue metallic
188,000 miles
Heads/Cam/Intake (tuned) 415hp 390tq
6 speed/4.10 rear
Very strong car. Runs and drives perfectly and has a reliable setup.
The following is a list of modifications:
Engine
LS1 346 CID
-SLP Lid+smooth bellow
-NGK spark plugs+Taylor wires
-Comp Cams 228/230 112lsa .585 cam
-AFR Mongoose V2 230cc 62cc aluminum heads with titanium valve retainers/AFR springs
-LS6 intake off a low mileage 04' Z06
-LS2 Timing chain
-LSA oil pump
All gaskets replaced, including rear main seal.
-Replaced water pump, alternator, power steering pump+reservoir+high pressure line.
Exhaust:
-Texas Speed stainless 1 7/8 long tube headers with fresh GM steel gaskets.
-Texas speed stainless y-pipe with 3inch consistent fabricated weld through pipe
-GMMG 3 inch catback with dual stainless tips
Body:
-Genuine GM 98-02 SS hood
-RK sport spoiler
-15' Z/28 emblems
-Gloss black grille with 15' Z/28 emblem
-5% tint side windows and t-tops, 20% rear hatch
-12 inch short antenna
-Whistler smoked housing headlights by DEPO
-Sail panel professionally removed and reinstalled with updated adhesive, which avoids bubbling in the sun.
-Interior is grey cloth/Ebony trim. I added a set of Ebony+vinyl door panels and charcoal grey cloth seats out of a low mileage 01 Z/28.
Electronics:
-NGK wideband
-Pioneer head unit+Bluetooth audio/steering wheel control module installed.
-(4) Alpine Type-R coaxial speakers (door/sail panel)
-(2) infinity speakers in rear hatch
-10 inch MTX Sub installed in hatch with correct enclosure, allowing proper t-top storage in trunk.
-Coaxial speakers are powered by a Power Acoustic amp located in the passenger quarter panel.
-Subwoofer is powered by a Rockford Fosgate Amp.
-SLP 02 eliminators
-SLP Skip Shift eliminator
-Replaced oxygen sensors
-LED fog lamps+reverse lights, halogen Silverstar Ultra headlight bulbs
-Window motors replaced on both doors
Suspension:
-Edelbrock strut tower brace
-BMR front and rear sway bars
-BMR lower control arms
-Moog ball joints/tie rods
-BMR welded subframe connectors
-Eibach Pro lowering springs
-Bilstein Shocks
Wheels:
-Fikse FM5 technipolish wheels with 2,000 miles (Imported from Fikse Wheels: Canada) -$4200
Front 17x9, Rear 17x11
Front tires- 275-40-17 Nitto NT555Extreme
Rear tires- 315-35-17 Mickey Thompson ET Street S/S
Brakes- EBC front slotted/dimpled brake rotors
Rear AC Delco rotors. (Ceramic pads all 4)
-Fenders professionally rolled for wide rear tires.
Drivetrain:
-Tremec T56 6 speed transmission with 30,000 miles.
-MGW short throw shifter
-Borg Warner brass shifter cup
-Genuine GM LS7 clutch kit with flywheel
-Tick Performance adjustable master cylinder
-Carbon shift forks
-Updated rear seal from 04' Z06
-10 Bolt 7.5 inch rear end installed from a 98' Camaro w/o traction control.
-T/A Performance rear diff. girdle with upgraded studs
-Motive Performance 4.10 gears installed by Slowhawk Performance with 1,200 miles.
Fuel system:
-Genuine Ford Greentop 42lb injectors
-Delphi fuel sending unit
-Racetronix 255LPH fuel pump
Known issue:
-Because the rear end was replaced with a 98' without traction control, the ABS INOP, Brake, and Service Vehicle lights are activated, causing the ABS to be turned off. Braking is still strong and consistent. No check engine lights are active.
-front bumper could use repainting
The vehicle was meticulously maintained by myself and my tuner, who worked at East Side Service: Wallingford, CT. The car is very strong and safely revs past 7,000 RPMs. No rust and paint is in great condition for its age. The front bumper could use reprinting. Otherwise it's a solid car. Over $30,000 invested
Navy blue metallic
188,000 miles
6 speed/4.10 rear
Engine
LS1 346 CID
-LS2 Timing chain
-LSA oil pump
Exhaust:
Body:
-RK sport spoiler
-15' Z/28 emblems
Electronics:
-NGK wideband
-SLP 02 eliminators
Suspension:
-Bilstein Shocks
Wheels:
Drivetrain:
-Carbon shift forks
Fuel system:
Known issue:
I worked in Wallingford, CT for 19 years (1989-2007). My sister has lived there for 30+ years. Nice town. And welcome to LS1Tech.com.
With 188K miles and that extensive list of mods I'm clueless as to what the value is. You'd know better than anyone having been the one to modify it. $30K into a 188K mile car is not seen very often....unless that includes buying the car for $10K-$15K. Looks nice as the miles don't show up in those pics. Repainted? I'm assuming the crank bearings/pistons have 188K miles on them. Somewhat similar in performance (or better) as the 2000 Berger SS. You've come close to rebuilding the entire car...for the better. A very specialized modified packaged. I could have seen myself buying this car 5 years ago - at the right price.
As a comparison, I value my 2 owner 1999 SS M6 with 18K miles at around $12,000-$12,500. Your car is no doubt worth more, but how much more? A 1 owner, 2002 SS M6 with 10K miles is probably worth $15K-$15,500 today. That might bound what your car could bring. And you'd need a cash buyer as well. Connecticut isn't the strongest market for these even if they are not very plentiful. I found my car in the Waterbury, CT area.
For what you have into it, I'd just drive the pants off the thing. You probably have Z06 performance at an F Body price. Your car must have made some track runs. Any ETs?
Highly modified cars can be tough to sell to begin with; a highly modified car with almost 200k on the clock is going to be even harder to sell for a decent price. You would probably come out ahead by stripping off what you can, like the $4200 wheels, and selling them separately. Also, wait until spring when the market picks back up before you try to sell it.
Wheels Dimensions and offset
Was wondering if you wouldn’t mind messaging me the offset you have for these wheels I would love to buy a set but don’t know exactly what is the good offset for them. Love the fitment of yours
SLPZ28ProStyle,
Sharp car, I really like the clean tasteful look - outstanding for a 188,000 mile car. Especially a mod'd 4th Gen.
Several years ago I tried to sell my one owner 154,000 mile heads, cam, intake 99 T/A with a roughly similar mod list with 4.10 gears etc - I had four offers in the $6,500 range that all fell through. Folks could honestly never get past the 150,000 + miles (and 120,000 of that with the heads and cam package).
Your car has nicer paint with much nicer wheels and has a much higher eye candy factor in its favor. Yet I think selling may prove slow and frustrating. I know you car is really worth ~$15,000 with the sweet wheels but it will be very hard to find that buyer. I suggest family heirloom for that sweet Z28
I decide to keep my 99 TA. New 8.8 rear end, RPM Magnum Level 6, and a custom 416 later its a family keeper now and I have no regrets. My stepson wants the car and eventually one day the TA will probably be his.
