99 SS M6 Turbo w/AC
99 SS M6 Turbo w/AC
So ive been back and forth with this, i DONT need to sell it but I have a lot on my plate and could realistically use the money elsewhere....
Ill be as transparent as possible, give me your honest opinions. Thanks in advance
1999 Camaro SS
Arctic white (clearcoat coming off in some areas)
Body has ~130k miles
T tops, no leaks
Iron 5.3 Gen 4 SBE ~ 110k miles
M6 w/ Spec stage 2 and Pro 5.0 shifter
Isky 215/215 112 cam
BTR .660 dual platinum valve springs
241 heads
Huron Speed V3 A/C Single turbo kit
ON3 7875 .96
Precision 46 WG
New melling oil pump
New water pump
New front lower A arms and ball joints
BTR push rods
LS9 head gaskets
Speed Master head studs
TA Rear end girdle
Magnaflow muffler
QTP 3" E cutout
AEM A/F gauge
Innovate scan gauge
Siemens 60# injectors
walbro 450 pump
hotwire kit
Wire upgrade
Subframe connectors
BMR AC Turbo K member
LCA's
Tick master cylinder
New MAF
Leather interior, Drivers seat completely reupholstered
Ill add more if i remember, car runs great, on a conservative tune, no issues driving it every day, AC blows cold
Cons:
Car was in a minor fender bender 2 years ago, had to replace SS hood and front bumper as they were both cracked
Car still has clean title but accident does show up on carfax
Body is 7/10
Interior is 9/10
LIke i mentioned, i dont need to sell, just throwing up a feeler!
1999 Camaro SS
T tops, no leaks
241 heads
ON3 7875 .96
Precision 46 WG
New water pump
BTR push rods
LS9 head gaskets
TA Rear end girdle
Magnaflow muffler
QTP 3" E cutout
AEM A/F gauge
Innovate scan gauge
walbro 450 pump
hotwire kit
Wire upgrade
Subframe connectors
LCA's
New MAF
Cons:
Body is 7/10
Interior is 9/10
