Ls1 with bad crank
Old Mar 7, 2023 | 02:28 PM
97camer's Avatar
Default Ls1 with bad crank
Well the crank end play is .003 oil pressure was20-30 There wasn’t much metal shavings in the bottom of oil pan,the rod side clearence was good,compression was 180-190 leak down
was real good like 4% cyl walls are good I took it apart because of lifter noise (the short block is still together) maybe the noise was the crank? Coulple scratches on the cam lobe but not bad lifters looked good.
i want to sell because by the time I buy a bigger cam and new short block I can buy a new crate engine - a lot less risk.
I would sell with out accessories with ls6 intake new injectors that are big enough for any cam.
thanks
Old Mar 12, 2023 | 07:26 AM
LS1Formulation's Avatar
A questionable LS1 longblock? Without knowing what heads are on it, I'd guess it might be worth $1000-$1500.
