335 Hoosiers on chrome 17x11's on again.
this is wat i want what mods would i have to do to fit the 17x11 with 325's and what size are those rims like off set an all that . thanks by the way my car is lowerd on sportlines
I had these same wheels and tires on my old car (99Z28) and that car had sportlines. Def. easier to fit with my Strano springs which I think is maybe an 1in of drop.
What it took to fit the 335 on my old car with the sportlines:
-Alot BFH work in the wheel wells
-Rolled the fender lip
-Removed half the bumpstop
-adjustable panhard bar is a must.
So 325s might be a little easier to squeeze in there. Still gona take some work.
bfh where ever it rubs
No, the bump stop (axle jounce) is an elongated pyramid looking part that attaches to the bodywork under the car. It hangs pointing downward toward a flattened section on the axle. When new, the jounce has a yellow or orange color. You can see the jounce easily when the wheel is off. The jounce will be the closest object to the rim and/or tire on the inside section. From the back of the car you can see that yellowish V part hanging down - that is the bump stop. That is if the picture shows up in the message.
![](http://i36.tinypic.com/2s9tahj.jpg)
Last edited by 01Z28M6; 10-20-2008 at 01:40 AM. Reason: trying to get picture in message - picasaweb problem
