which drag radial?
Old Nov 25, 2008 | 11:09 PM
VaderZ's Avatar
Default which drag radial?
I'm running my 02 Z28 with a cam only set up, 3600 Vig. Stall and 3.42 gears n/a. I was wondering which drag radial tire I should go with. Should I go with the Mickey Thompson ET Street Radial Tires or Hoosier D.O.T. Drag Radial Tires?? I have 15x10 pro stars.
Old Nov 28, 2008 | 10:04 PM
VaderZ's Avatar
Old Nov 28, 2008 | 10:18 PM
DopeFedZ's Avatar
My vote is for the M/T.
$O$OE's Avatar
M&h.....
Old Nov 28, 2008 | 11:51 PM
'Trust''s Avatar
M/t 100%.
Old Nov 29, 2008 | 02:10 AM
ZTwentyAteU's Avatar
Mickeys definately. I run 325/50/15s. They fit in the wheelwell and my car launches wheels up every time
Old Nov 29, 2008 | 07:28 AM
blk/slvr02ss's Avatar
They are both good sticky tires but the M/T ET Streets don't sway @ high speed.
Old Nov 29, 2008 | 08:13 AM
Chris05ssTruck's Avatar
The wear is better on the ET's...they will last a lil longer. The hoosier radials work as well tho! Just wear a lil quicker.
Old Nov 29, 2008 | 08:15 AM
98z8uup's Avatar
My vote for the M/T's.
Old Nov 29, 2008 | 08:18 AM
Ryans_pewter_ss's Avatar
I ran the et street radials and went a 7.18 then changed tires only to et street and went a 7.07. But like he said they sway at higher speeds. Its a ride gearing down and passing someone with the et streets. The radials ride just like a street tire though.
Old Nov 29, 2008 | 09:10 AM
In my 02 SS i was wide open racing a 07 C6 Vert w/ M/T ET Street Radials and there was no sway at all and they do last. I have had them now for 2yrs and about 1600 miles and i would say there about half way.
Old Nov 29, 2008 | 09:50 AM
PewterScreaminMach's Avatar
MT ET Street Radials.
Old Nov 29, 2008 | 10:00 AM
rojs234's Avatar
Do you guys run them on the street much, or do you just change them over when you are going to the track? Ron
Old Nov 29, 2008 | 10:16 AM
KBG's Avatar
KBG
Everyone is going to recommend what they run naturally but I have had great luck with the hoosiers.....they wear quick but they HOOK.....I run them as my only tire and drive on the street way more than the track I just have to make sure and check the weather first......I really wouldn't want to be caught in a heavy downpour on ANY type of drag radial
Old Nov 29, 2008 | 10:58 AM
ndfrsd6's Avatar
mickey's ....
Old Nov 29, 2008 | 12:10 PM
Strahley's Avatar
M/T
It's the only way
Old Nov 29, 2008 | 12:17 PM
GR8GAME's Avatar
Mickey T's
Old Nov 30, 2008 | 06:10 AM
93ls7z's Avatar
Hoosiers hook on mine better than anything else has. I am running 275/60/15.
Mike
Old Nov 30, 2008 | 02:39 PM
GDBY2U's Avatar
Restricted User
I'm Runnin A Set Of The New Hoosier D.o.t.Radials... These tires Can Hook In A Car Wash!!! Awsome!!
Old Nov 30, 2008 | 06:32 PM
98Camarod's Avatar
I was going to ask about the hoosier radials, I had good luck with the mt et streets, but I'm thinking about the hoosiers.
