Draglite owners inside
Pics are greatly appreciated along with fitment advice. This will be the first set of drag wheels I have ever owned. And I can't find very much stuff with the search for Draglites. Way more Prostar, new Welds & bogart postings, so any help and advice is appreciated for this specific wheel.
Your 10 bolt wont like this mod!!!!
Seach wil prolly help you,pics will be in there for sure too.Not a really big deal with the 15x8 just a little bit of grinding.My 15x10 were a little more work,bumpstops were cut out and a little hammerin. I'm planning a Midwest Chassis 9" by the time I get ready to run these, so the 10-bolt won't ever have to worry, LOL.
I was hoping you had something in the works!!You are gonna have to test fit the rim,and grind down the caliper were it touches.Not a big deal,it not compromising the caliper integrity.On my setup i rounded off the caliper face and corners as well as the top.Just grind untill the desired clearence is achieved. o and grind more than you think you need to off... i have had to take mine off twice and regrind, once you take your rims off one time and put them back on, they will probably grind again..
grind grind grind grind grind... lol
good luck
side note: now would be a good time to do your brakes, because whenever you put new(er) pads on, it will push the calipers out, towards the wheel more. And you will have to grind more.
good luck
just keeps you from grinding so much, and i hardly ever launch with my sticky tires on.. so... i dont know.. hahaha
thanks though..
Dont use spacers on the rear!!!Im only using them on the fronts.
