need help about MT tires
Old Dec 2, 2008 | 02:24 PM
PONTIAC SLP's Avatar
Default need help about MT tires
Hi , i installed Mickey Thompson ET Street, 26 x 10.5 x 16 , how much should i mobilize tires PSI ? next week i'll race a bike (Kwasaki 1100) with 150 of spray the distance will be 60 MPH the end 600 meter , my rear end is 4.10 so i'll start in the third gear with the shoot , my friends said make them 25PSI ? are they right ?
Old Dec 2, 2008 | 02:27 PM
KBG's Avatar
KBG
personally if you're starting at 60 mph I don't think you'll spin but I personally would run 18-20.....that's just me though.....you'll get different opinions
Old Dec 2, 2008 | 02:28 PM
ndfrsd6's Avatar
i personally would run about 20psi ...
Old Dec 2, 2008 | 02:38 PM
guys if i want to start from a stop how much should i run the RPM ? 2 RPM good or less ?
Old Dec 3, 2008 | 07:34 PM
DopdBrd's Avatar
If you are going from a roll, and starting in 3rd, you better be starting at around 60-70 MPH. Even with the 4.10's 3rd will handle that MPH.
If you go from a dig, I would hope you could launch it a little harder than 2,000 RPM's but you are going to have to remember something.
YOU ARE ON THE STOCK REAR!!! Those things with 4.10's do not like sticky tires at all. I know because I went through 2 rears in less than a month before buying my Dana 60.
I would run about 18-20 psi in them.
Old Dec 3, 2008 | 10:16 PM
loool yes stock rear end and i'm scary for that my buddy said try 6,000 with shoot from a dig looooool then i said for him if its broke u will buy new one for me he said call me loooooooool he mean forget that looooooool
