how do i
Old Dec 4, 2008 | 02:19 PM
Big Bird WS6's Avatar
Default how do i
345/35r18
305/35r18
how do i fit either one of these in the back?
the 345 are 27.5" tall
and the 305 are 26.4" tall
is this do able?
Old Dec 4, 2008 | 08:00 PM
no one?
Old Dec 4, 2008 | 10:40 PM
2000ssowner's Avatar
heres a link hope it helps: https://ls1tech.com/forums/wheels-ti...must-read.html
Old Dec 5, 2008 | 01:36 PM
Xsta Z 28's Avatar
The 305's are easy, just mount on a 18" x 10.5" or 18" x 11" wheel. Offset somewhere around 45 to 50 mm.
The 345's IMHO won't fit.
Old Dec 5, 2008 | 01:50 PM
ok one last.
how tall can i fit in our cars. 27", 28", 29"
thanks.
oh and with the 345. how much tubbing would have to be done? and would i have to move LCA mount in?
Old Dec 5, 2008 | 02:08 PM
ZFSix's Avatar
Depends on which 345s. I've seen a set of 345/35-18 M&H's that were actually about as narrow as a 315 or maybe 325, and I really think you could get those to fit if your car is not lowered in the back.
Lots of guys run 28" slicks on these cars, not sure about the suspension though, I know you can't lower it with 28s, so I guess you need stock springs and some adjustable shocks or something.
The 305s will fit easy.
Old Dec 5, 2008 | 03:05 PM
Xsta Z 28's Avatar
28" is the max I believe, and there still may be some body mods for that. Not too versed on drag tires.
Old Dec 5, 2008 | 06:14 PM
well i am planning around mickey tires. and there is an inch difference in tread width. for traction does an inch make that much difference?
