backspacing question
Old Jan 5, 2009 | 10:32 AM
SHDY 5.7's Avatar
Exclamation backspacing question
I hope this is the right section. I have a 96 formula,I have the rear prostars but I've been on a search for a set of fronts. I found some with tires for very cheap. They are 2.25 backspacing though. Can I use these on my car?
Old Jan 5, 2009 | 10:56 AM
ndfrsd6's Avatar
you will have to grind the calipers ....if you can get 1.75 bs and put a small spacer with longer studs and you should be fine (no grinding)
Old Jan 5, 2009 | 11:23 AM
SHDY 5.7's Avatar
Yeah I had to grind my rears. I can get these rims dirt cheap so I may deal with the grinding. So I can use them with the exception of grinding the calipers?
Old Jan 5, 2009 | 12:36 PM
ndfrsd6's Avatar
you should be fine just get a spacer to help minimize the grinding
