This should work with no problems, I hope??
Will this be OK with no tire rub, fit problems, etc???
17x11 rear and a 315/35/17 front will be a 17x9.5 and a 275/40/17
Would I have to adjust the speedo settings?
Looking to change out the stock wheels and get some DR'S out back after my combo change requires me to now.
Any input/suggestions much appreciated...
Really was in hopes that the 17X11 would fit out back with no problems....
Really need to do something in the spring as I wore out what I have on the SS after getting the car back from Speedinc last summer. Thanks for any help/advice...
You dont always have to use a BFH on the wheel well either, or get an adj panhard either. I didnt have to use a BFH and I eventually got an adj panhard rod...but not because I needed it, well i needed it, but not because of rubbing or anything.
Fact is, each car is different. So you might have to do all those crazy things, and then again you might not have to do anything to get them to fit.
I didn't have to do anything to mine when I mounted 17x11 with 315 Nittos. Put them on and went on my way, never having them bump or scrape anything.
Here's a tip, if you are having trouble getting the rear wheels on, with them hitting the bumpstops while trying to push them on the studs, jack the car up from the pumpkin instead of from a jackpoint on the frame rail. This will load the suspension and give more room to clear the bumpstop.
And I don't have a TA...
