Widening a factory 17x9....will you need a mini tub
Is it a waste if time to widen it to 17 x 11? Is it a bad idea in any way.
Will they fit back on the car just fine or do I need a mini-tub or something else?
Its a 100% street car, I don't do anything crazy as far as twisties. I've had 315/35/17's on my rear factory rims for the past 7 years or so and they ride great and they wear perfectly even every time. Going on 17,000 miles out of my 3rd set of GS-D3's and they're still good for another 3-4 months.
I'm having my factory rims re-polished and the same company (www.fixrim.com) also does rim widening, so I might as well get it done while they are there.
Lets hear it.
**Except that 315's don't work on 17 x 9's and you shouldn't do it, because thats just ridiculous, don't need to hear that garbage***
Lets hear it.
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
No tubs necessary if you use the right adapters. I will give you 3 free hits for this question. But the rest can be found searching for the words widen or widening (at least 15 pages of threads on this one topic)
https://ls1tech.com/forums/showthrea...ferrerid=13535
I saw in one of the links that someone successfully went with 335's on the rear with no rubbing.
How wide does the rim have to be widened for that size tire? I'm gonna need it.
I have 335-35-17's on my 11" widened WS6 rims, 1/2" spacers and 1/2" longer ARP studs, and removed the bump stops and rolled the finder lips and a BFH the inner finder in the front area,But I did all the work for the 315-35-17's ,so the 335's fit also. You will need a adjustable pan hard rod to canter the rear end, because youll need every bit of the room you can get
Or will FixRim who's doing the work have all this stuff for me?
Thanks.
