Pics Of My Jegstars.......
Looks good!! Looks identical to my car when I had lightened the nose up. I'd give the no center caps a try. I like how they look on my car with no center caps an the hubs painted black.
taped them off 1in. down,used a cuttoff wheel and cut relief cuts down to the tape about every 1 1/2inches,then bend each section out 90deg. ,then use the cuttoff wheel to cut them off to about 1/8th of an inch. (if your cuts aren't perfect it dont matter, you wont be able to see them)
