Lost "key" to wheels
Old Feb 14, 2009 | 07:01 AM
dochall22's Avatar
Default Lost "key" to wheels
The special socket for the theft deterrent lugnuts - yeah - cant find it - It came with the car, it's got ZR1s factory style - would the socket have came with the car from the factory or is it aftermarket add on?
Old Feb 14, 2009 | 07:23 AM
KroMiniX's Avatar
Probably an after market add on from the previous owner. The same thing happened to me so I went to advanced auto parts and found a matching one. If anything you can go to a local wheel/tire shop like a goodyear and they can strip it off for you.
Old Feb 14, 2009 | 07:26 AM
dochall22's Avatar
How do they strip it? Will it damage the rim at all?
Also - how hard was it to find a match?
Old Feb 14, 2009 | 08:04 AM
KroMiniX's Avatar
No I don't believe they would damage the wheel at all man. Someone told me they have a tool for that. I think it will be fine. As far as finding a match I found it easily, but maybe i just got lucky that the previous owner bought them at advanced. Go look at least. Take a picture of the lock and try to find a match thats what I did.
Old Feb 14, 2009 | 08:18 AM
evilZO6's Avatar
you dont need a tool, just tap a 5/8 socket on top. then go to any parts store and buy a new locking set of lugs. I prefer Les Schwab becuase they use gorilla. They supply a sticker so that if you ever lose it again, you call the number on the sticker and give them the number off the sticker and they mail you a new one specific to the kits you originally purchased.
Old Feb 14, 2009 | 08:20 AM
C-Sicz's Avatar
The snap-on man sells a socket that you can hammer on to the lug and it will get it off. Don't plan on reusing the lug though!
Old Feb 14, 2009 | 08:32 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Pound a socket on that biotch
Don't be scared Doc
Old Feb 14, 2009 | 08:38 AM
dochall22's Avatar
i know i know!!! I've thought about it!
dochall22's Avatar
the lug or socket?
Old Feb 14, 2009 | 08:43 AM
C-Sicz's Avatar
Originally Posted by dochall22
the lug or socket?
The socket is reusable. It cuts into the lug and grips onto it. So for obvious reasons you can't use the lug again. Good luck
Old Feb 14, 2009 | 08:47 AM
dochall22's Avatar
would there be something like this at sears ya think? I dont have a snap-on guy!
Old Feb 14, 2009 | 08:54 AM
C-Sicz's Avatar
This would work too, similar concept
http://cgi.ebay.com/ebaymotors/Emerg...Q5fAccessories
Old Feb 14, 2009 | 09:07 AM
C-Sicz's Avatar
If you go with the performance tool set, you might be able to find them at Auto Zone
Old Feb 14, 2009 | 09:15 AM
SS02's Avatar
Buddy's got a tool, I had the same thing happen, the lug was fine, but you need the key to put it back on lol, so if you can in my opp get the tool required. Takes 3 seconds on the impact.
Old Feb 14, 2009 | 09:19 AM
therealcreeper's Avatar
my dad has a set of wheel lock removers for f-body's and corvettes. i had to use it to get my wheel locks off. i was pretty annoyed when i went to put in new brake pads and found out that i couldn't get the wheels off. the backs didn't have em.
all it is is a socket with no teeth in the middle. it's just round. you put it on an impact wrench and spin it til it heats up. then as it cools it contracts and grips the lock, then you just loosen it.
Old Feb 14, 2009 | 09:36 AM
dochall22's Avatar
thanks for all the input guys - appreciate it - i think i'll hit up autozone on the way home from worky work
Old Feb 14, 2009 | 12:29 PM
TORK?'s Avatar
Maybe you could weld another nut to the end of it and draw it out that way? I guess there would be the risk of getting some junk on the wheels.
This worked to get stripped flywheel bolts out though.
Old Feb 14, 2009 | 08:58 PM
wht01ws6ta's Avatar
I temporarily misplaced my key and just pounded a socket onto the locking lug, was 19mm I think, and it didn't take an incredible amount of force to get it to stick enough to get the lugs off. After removing a lug I heated up the socket a little to get the lugs out of it and the lugs are still good to go (and although the socket looks a little rough it is still 100% useable)
Old Feb 14, 2009 | 09:23 PM
93blcZ28's Avatar
Been there done that lol, still need to go get some new ones
