Tire Pressure...
Old Feb 16, 2009 | 04:23 PM
Adam2001WS6's Avatar
Default Tire Pressure...
I've got a set of Falken Ziex ZE329 245/45Z17s and I'm trying to determine optimal air pressure in these things. Falken's website says max 50psi (cold) which obviously isn't what I'm supposed to be running them at. I'm attemptng to get ride quality as well as even tire wear/longevity out of these things. Any help?
Old Feb 16, 2009 | 04:34 PM
Nova5's Avatar
appear to be stock size if i remember right. follow the door panels ratings for it.
Old Feb 16, 2009 | 05:42 PM
The sticker is for 275s. Does this make a difference?
Old Feb 16, 2009 | 06:07 PM
Nova5's Avatar
Pressure is determined more by weight + weight distribution in the vehicle than tire size i belive. Someone correct me if I'm wrong. 35psi around in my Z28. Stock Z28 comes with 245,40-16s
Old Feb 17, 2009 | 05:50 PM
So, I'm definitely running low on between 22-25...?
Old Feb 17, 2009 | 10:26 PM
4.6what's Avatar
yes. i run 40 - 41 in everything i own and they always wear like they should. well the front ones do.. the rears always seem to wear a little quicker for some reason
Old Feb 17, 2009 | 10:51 PM
fordeater's Avatar
32-35 psi should be good..
Old Feb 17, 2009 | 11:22 PM
Black02SLPSS's Avatar
Couldnt imagine why that is...
Old Feb 18, 2009 | 07:09 PM
What's with people running different pressures in the front and rear?
Old Feb 18, 2009 | 07:56 PM
4.6what's Avatar
lower pressure in the rear promotes better traction
Old Feb 18, 2009 | 08:02 PM
99345hp's Avatar
Only on a racing type tire. On a radial street tire you will loose footprint running low tire pressure. The center of the tire wont have as much contact with the road as it would if you had the correct tire pressure. If you run too much pressure the center will be the only thing with good contact with the road.
Experiment to what gives you the best traction and feel at highway speeds. Low tire pressure will make the car feel unstable at high speeds. I would guess optimal would be somewhere between 32-40 psi.
Old Feb 18, 2009 | 08:04 PM
4.6what's Avatar
good point
Old Feb 18, 2009 | 09:16 PM
Lotus289's Avatar
I run both sets of my tires around 42psi. Any lower and I can feel them 'biting' the road and get a sloppy fell like the sidewall is rolling under the rim. FYI I run 275/40/17 in the summer and 225/60/16 in the winter. Both between 40psi and 42psi
Old Feb 19, 2009 | 12:36 AM
Anthony '00 WS6's Avatar
Check the Door Panel should say 30-32psi all the way around.. thats what i get for working at discount tire
Old Feb 19, 2009 | 09:37 AM
SS SLP2's Avatar
last 20 years I have ran max psi on side of tire ,(44 psi) I get 40-45k on all set with very even wear no cupping or side wear(do ride a little harsh) now one car with 37 k and one has 43k on the other and if you can find ANY abnormal wear on any of my tires I buy you a steak dinner( or I might buy you a set of new tires)
Johnny
Old Feb 19, 2009 | 09:58 AM
WildRidez's Avatar
I run my tires at 30 or 32 psi. Always have them wear fine
Old Feb 20, 2009 | 07:28 PM
Good info. friends. Thanks so much.
Just fired up the air compressor.
