replacing stud on dana s60
o yea. i talked to the ppl at strange and the stud they used are m12, 1.50 pitch, 50mm long, and the head is a hex. i have looked at autozone all they had that was close was a m12, 1.50, but a 54mm, non hex head. will this work? or do i need to have the excess 4mm machined off? or should i just suck it up and order replacements via strange directly? (min of $10 + shipping)
and i dont have the net at my house. only at dads. so it may be a day or so before i can reply.
thanks all in advance.
drain the rear, pull the calipers off.
open the cover, push the axle in, remove the c clip (if it has a clip clip, not sure if c clip eliminators are used on S60's)
pull the axle out. push the broken stud out on a press and press in the new one,
The extra 4mm in length shouldnt matter.
thanks. i was afraid of that. i finally got a reply from someone at strange that said that since i have abs its gonna be a bitch cause something has to be pressed to get it out. i know normally u just beat the bitch's out but there is a part in the way. ill try to get a pic to show everyone.
transam69230 - with you not having to use the reluctor rings you should be fine changing out the stud without actually needing the new seal or bearing
