drag wheel backspacing?
Old Mar 31, 2009 | 12:09 AM
SSIRBY's Avatar
Default drag wheel backspacing?
is there a thread anywhere? just wanna know the backspacing for front and rear of an 98-02 fbody w/out having to use a spacer. right now i have holeshot holestars, 15x4 15x10. rears 7.5, front not sure, gotta measure. front spacer is 3/4, rear is 5/16. i've done grinded to get them to fit, but do i need to grind more to get them to fit w/out a spacer?
Old Mar 31, 2009 | 07:47 AM
021less's Avatar
the sticky up top has some good info in it....
Old Mar 31, 2009 | 09:01 AM
SSIRBY's Avatar
ok thanks.
Old Apr 1, 2009 | 01:42 AM
9sec93's Avatar
you will not fit those rims without spacers unless you have drag brakes. the back of the rim is flat so measure how far the caliper sticks out past the rotor where the rim sits and that will tell you the minimum spacer you can run.
