These probably wont fit am i right?
Old 04-03-2009, 10:00 AM
mvrotc's Avatar
Default These probably wont fit am i right?
BRAND: OE Concepts
STYLE: Corvette Replica
SIZE: (2)18 x 8.5, (2) 19 x 10
Im looking to by these and put them on my camaro 99, z28 stock rear. Is this possible? What size tires would i need?
Old 04-03-2009, 06:29 PM
99Bluz28's Avatar
Lightbulb
The fronts will probably be no problem, but the rears might need 1" to 1.25" hub spacers.
If you could post the front and rear wheel offsets, then I could give you a clear answer.
Old 04-03-2009, 06:31 PM
spaz1's Avatar
I'm running 10 wide wheels in the rear with a +42 offset and no problems at all I am only running a 295 tire on them. You can get those wheels in the proper offset from tomzwheels.com
Old 04-04-2009, 12:45 PM
AK's WS6's Avatar
With oem offsets I've heard the fronts will fit, but it's the rears that are off, I believe they have like a +79 offset
