MT ET Street Radials
Old Apr 13, 2009 | 06:09 PM
CamaroKidZ28's Avatar
Default MT ET Street Radials
Ok, not sure what size MT ET Street Radial to go with. Car is driven often, but not worried about rain and etc. Car made 620 crank, not sure about whp but its through a TH400 with 2500 tq converter and 12 bolt
Rim is 15x10
325 50r15 or 315 60r15? Other?
I have air shocks in the back so i can fit it I think.
Any opinion welcome! Thanks,
-Mike
Old Apr 13, 2009 | 08:28 PM
o.0 .
Old Apr 13, 2009 | 10:19 PM
35 views no thoughts? lol
Old Apr 14, 2009 | 09:44 AM
Camaro396's Avatar
What rear end gear are you running? What RPM do you spin the motor to? What's the backspace on the wheels? Is it for the 2nd gen in your sig?
Old Apr 14, 2009 | 09:47 AM
Camaro396's Avatar
Oh and by the way, it's going to be a pain to fit a big tire with air shocks, because they are so big. My tires wouldn't even go on, until I put some Comp Engineering drag shocks on the car. I ran 315/60R/15's (30" tall tire) on my 72 Camaro, on a 15x8 rim, but to fit a tire like that, your springs better be re-arched, fender lips rolled, and you better have a lot of gear, and spin the motor hard.
Old Apr 14, 2009 | 12:24 PM
3:73s, 5800 rpm peak hp, has traction bars and air shocks in the back, 2nd gen in sig
Old Apr 14, 2009 | 12:53 PM
Camaro396's Avatar
With that kind of gear ratio and RPM, you're probably going to want to stick with a 26" tall tire. Does it see the track alot or is it more of a street car? If you're just building a cruiser, it doesn't really matter, and 28s will probably look cooler.
Old Apr 14, 2009 | 02:20 PM
Its mostly a street car, looking for traction on the street as well as figuring it will look bad ***.
Ive yet to take it to the track, plan to once I get DRs and a harness.
Thanks for your help
Old Apr 14, 2009 | 02:33 PM
What tire would be fastest on the track/street?
Old Apr 14, 2009 | 08:00 PM
Camaro396's Avatar
275/50/15 would probably be best for your gearing and RPM.
These are 315/60/15s on my old wheels. 15x8 3.5 backspace.
This summer I'm running the same tire, and using a 4.88 gear, TH400, 5000 stall, and spinning to 7200.
Old Apr 15, 2009 | 08:36 AM
STEEPSS's Avatar
have any shots of this car in action^^^??
looks sweet man.
Old Apr 15, 2009 | 10:15 AM
Camaro396's Avatar
looks sweet man.
Thanks! Not really too many action pictures yet. I had a fire with the car two years ago, it almost burnt to the ground. It's slowly coming back together now. Just got the motor/trans back in last week. I have to order the new front fenders, hood, front end, and have the 9" built for it, and have the 12pt done, and it will be ready to go.
Pre fire:
After fire:
Last week:
Old Apr 15, 2009 | 12:51 PM
Man that looks badass im so tempted to run the 60r15.. hm.. thinking of going 325 50r15
Old Apr 15, 2009 | 04:03 PM
Camaro396's Avatar
This is the 325/50R/15 on my 2000 Z28.
Old Apr 16, 2009 | 11:45 AM
Man thats sexy, love both those cars.. that tire setup and that hood look pretty bad ***
