Skinny?
Old May 6, 2009 | 06:26 AM
  #41
Camaro396's Avatar
For Weld Prostars you have to grind a little bit, or use a small spacer. If you use a small spacer, it's recommended that you go to an ARP 3.250" wheel stud.
Old May 6, 2009 | 01:06 PM
  #42
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Just tell who ever you are ordering form that you need the lugnuts to go with the wheels and they are going on whatever you car is(assuming the 02 TA in your sig). I'm running the MT Sportsman tires as well
This is the style lugnut you need
http://store.summitracing.com/partde...t=WLD-601-1412
Old May 6, 2009 | 01:55 PM
  #43
Camaro396's Avatar
I already linked him to the correct lug nuts. If he is going to use a spacer, he will need the 3.250" wheel studs, so the lugs you have linked here wont work.
Old May 6, 2009 | 03:32 PM
  #44
Z28/2002's Avatar
Thanks
I realized after I posted that I was about 7 hours too late and figured he already had the right parts
