Skinny?
Old May 4, 2009 | 10:48 PM
Italiankid77's Avatar
Default Skinny?
I need to buy skinnies what size,bolt pattern,and tire size thanks for the help.
Old May 5, 2009 | 02:10 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
The info is all over this section but see below
5x4.75 bolt pattern
15x3.5 with 1.75 BS
15x4 with 2.25 BS
tire depends on what your needs are. I'm running 26x7.5x15 MT Sportmans
Old May 5, 2009 | 11:09 AM
TurbopigB4C's Avatar
So are wheel spacers a must on 15x4 with 1.75 backspacing?
Old May 5, 2009 | 11:23 AM
Z28/2002's Avatar
I'm running the 4s with 2.25 and I have a 1/4"(I think) spacer on mine. I also had to do the normal caliper grinding
Old May 5, 2009 | 11:27 AM
I have not tried to install mine yet just ordered the tires for them do they look like they are in to far without the spacer on yours?
Old May 5, 2009 | 11:38 AM
Camaro396's Avatar
Weld R/T wheels are 15x4 with 1.50" backspace and fit without spacers or grinding, and to my suprise tuck fairly well.
Old May 5, 2009 | 11:56 AM
Thanks that's what I needed to know
Old May 5, 2009 | 12:14 PM
So im looking at jegs witch ones would I order,in the 15x4 the first or second ones??
http://www.jegs.com/p/Weld+Racing/746350/10002/-1
Old May 5, 2009 | 12:15 PM
blown03mustang's Avatar
i didnt like how they looked with a spacer so went ahead and ground the front a little to make them fit. plus i feel a little safer that way
Old May 5, 2009 | 12:16 PM
summit stars are better imo
Old May 5, 2009 | 02:59 PM
Z28/2002's Avatar
Here is a pic of the 4s on my car
https://ls1tech.com/forums/11502770-post5.html
Old May 5, 2009 | 05:20 PM
Ok so when it comes to ordering these im clueless,witch ones do I order from jegs the first ones or the second ones in the link??
Old May 5, 2009 | 05:36 PM
Z28/2002's Avatar
The bolt circle MUST be 5x4.75 and whatever size you decided on
Old May 5, 2009 | 08:10 PM
Is this the right one??
Size; 15'' x 4''
Bolt Circle: 5 x 4-1/2''
Rear Spacing: 2-1/4''
Old May 5, 2009 | 08:41 PM
Camaro396's Avatar
Size; 15'' x 4''
No.
You want
Bolt Circle: 5 x 4-3/4
Rear Spacing: 2-1/4
http://www.jegs.com/i/Weld+Racing/927/96-54202/10002/-1
Old May 5, 2009 | 09:00 PM
Whats better to run 15x3 or 15x4??
Old May 5, 2009 | 09:03 PM
Camaro396's Avatar
I have used both. Both are fine.
Old May 5, 2009 | 09:09 PM
I dont know witch ones to order now??
Old May 5, 2009 | 09:18 PM
Camaro396's Avatar
Just get the 15x3.5s
Old May 5, 2009 | 09:37 PM
Ok I ordered these
Size: 15'' x 3.5''
Bolt Circle: 5 x 4-3/4''
Rear Spacing: 1-3/4''
