caliper shaving
Old May 6, 2009 | 10:09 AM
99bird's Avatar
Default caliper shaving
Need help, caught a good deal on 15x10 weld rodlite's. Wondering if caliper shaving is needed.Thanks.Before i shave can i use spacer.
Old May 6, 2009 | 10:52 AM
STEEPSS's Avatar
if they are the correct backspacing (7.5 inch) then you will need to grind your calipers.
Old May 6, 2009 | 12:48 PM
99bird's Avatar
Nope, had one of those shoulda/woulda moments. They are 5.5. Is there still a way for them to fit.
Old May 6, 2009 | 12:50 PM
keith_AE2010's Avatar
It won't look right. You need to shorten your rear end.
Old May 6, 2009 | 01:06 PM
STEEPSS's Avatar
they will stick out ALOT. personally, i would just pass the savings on to someone else. aka sell them. and buy some the correct offset. that's just my opinion though, and i have been wrong before.
i'm not sure if the different BS changes how much you have to grind, but with my 7.5 BS prostars, it was about an hour per each rear caliper.
Old May 6, 2009 | 05:26 PM
Camaro396's Avatar
15x10 with 5.5 backspace will NOT fit without narrowing your rear end 2.0-2.5" on each side.
Old May 7, 2009 | 02:31 PM
99bird's Avatar
good purchase gone bad. Should have done more research.Weld rims for sale... anyone.
Old May 7, 2009 | 02:36 PM
99bird's Avatar
That will be my next step. I had ask summit about bs, they say it dosent even come in 2".
Old May 7, 2009 | 02:58 PM
Camaro396's Avatar
How much?
Old May 11, 2009 | 02:35 AM
99bird's Avatar
200 out the door.
