Pro star problem
Old May 20, 2009 | 08:35 AM
blackz6sp's Avatar
Exclamation Pro star problem
Well I thought I had a bad set of tires, but it looks like my rear pro stars aren't centering up. Has anybody had this problem with rear pro stars? It make the wheel look out of round and a serious vibration.
Old May 20, 2009 | 10:07 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Have you clearanced the calipers or put a spacer on it yet?
Old May 20, 2009 | 11:03 AM
blackz6sp's Avatar
Yep, no spacer. Not a clearance issue. Balancing, out of round, not centering issue.
Old May 20, 2009 | 03:45 PM
SJM Manufacturing Inc's Avatar
If you have your star washers still installed on the studs, remove them.
Old May 21, 2009 | 10:32 AM
blackz6sp's Avatar
Stars are gone. Not an in and out wobble, a up and down movement.
Old May 21, 2009 | 01:34 PM
bowtiebuilder's Avatar
Have you had the wheels/tires balanced? Or checked again?
Old May 21, 2009 | 06:24 PM
blackz6sp's Avatar
Yep did a stud centered balance on them (not a hub centered), it helped the vibration but it's still there. Just lookin to see if anybody else has had the problem, not really lookin for solutions.
Old May 22, 2009 | 01:04 AM
OOOJOHN's Avatar
I've never had any kind of problem with mine.
Old May 22, 2009 | 09:45 PM
I got 3 sets on 2 different cars... no problems at all.
