Spacers in the rear?
My question is this: I don't really want to grind much, so how much of a spacer should I run? In other words, how much gets ground down for you guys that just grind and don't run a spacer?
I will be going to a 3.5 inch ARP wheels studs to make sure I have enough threads for the lug nuts with the spacer. This is the one.
http://www.summitracing.com/parts/ARP-100-7713/
I was thinking about a 1/2 inch spacer. I don't care if they stick out a little, just don't wanna grind...and I definitely wanna be safe about it all.
Does the new studs and spacers sound good with these or will I still have to grind some for the draglites. These are stock brakes and weld draglites.
