Newbie rim & tyre questions
Hi,
I've been reading howstuffworks.com
and got a few questions....
I will (one day
) be buying new rims and tyres, I like TT2's.
I'm not really into drag racing, and the roads here have lots of tight corners. I'm in the UK, so I need tyres that can handle some rain, and resist hydroplanning. Although 80% of my driving is fair dry weather, and I only occasionally getting caught out in showers.
I read that for better traction during cornering , a lower profile tyre better resists the forces generated, due to the stiffer sidewall.
But I don't want to reduce my off the line traction either (I want it all syndrom lol!) I have some traction issues already....![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
I also read that wider than stock tyres can 'track', pulling the car to one side on certain parts of the road, I guess due to road camber (I get that alot already with my stock ws6 rims!).
For my needs, please tell me:
1. What size rims should I get, stay with 17", or step up to 18"s with a lower profile tyre, f+r ?
2. Should I get wider back rims, and step up to 10"?
3. Would lower profile tyres really benefit me in the corners?
4. If I swich to lower profile tyres, will I lose traction off the line, and if so would it be much?
5. What type of tyres should I get? (radial/streets,
I don't really know the differance).
6. What's the highest speed rating for tyres?
7. Unrelated, but FMI,
Can I fit tyres with a bigger sidewall in the rear to help with off the line traction onto my stock rims? (there looks like spare space back there.......)
Thanks for helping me with my choices....
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
I will (one day
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
![Newbie](https://ls1tech.com/forums/images/smilies2/newbie.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
for your TT2s get a 17x9/10.5 combo with Goodyear GS D3s. 275/40/17 up front and 315/35/17 in the rear. they will help you a lot on the corners, and with 315s in the back your off the line traction will increase. as for your current wheels, there are 275 drag radials with taller sidewalls. a 285/40/17 would have a little taller sidewall. hope this info helps
Hi,
Thanks for your reply Hitmanws6, just the info I am after.
Curently in the rear I have cooper cobra and zeon, both are a 275/40/R17, but the cobra is slightly wider & higher, with a sidewall of 87mm vs zeons 83mm! (Noticeably different when lined up off of the car)
I'd just like to confirm I have understood this part:
JFMI, you are telling me I could put a wider tyre on my stock rims (285) and that would also increases the aspect ratio, making for a bigger side wall as well ? (All be it a very small differance).
So the lower profile tyres up front don't really help for cornering? (I do see that the 315/35/17 TT2 for the rear are a lower profile)
Many thanks for the guidance and info, 10.5" will be going on the back one day![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Edit: You say 315 in the rear. Is that a 315 tyre, on a 10.5" rim???![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Thanks for the help......
yes, the 315 would be for a 10.5" wheel. Don't get 18s. I know they look good but they do not hook very well and the tires are a hell of a lot more expensive. Why not get some 15"s? They're the new 20"s!
Great, thanks for confiming that NBMZ/28.
20s on a fbody don't look right IMO, but 15s with friggin great rubber do.![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
I just want to set my car up more for corners than drag racing.....
I'm also considering the possability of having my ws6 17" rims made wider into a 10.5" (I do like my ws6 rims, they just need a referb) .
Is this a bad idea, or safe to do and worth considering??
