ceramic wheel bearings
Old Jun 15, 2009 | 01:09 AM
badmfkr's Avatar
Default ceramic wheel bearings
has anyone here upgraded to ceramic wheel bearings?
makes sense to me much less fiction means I get to go faster and be more effisheiant.
Old Jun 15, 2009 | 06:54 AM
leadfoot4's Avatar
There was a discussion about this several months ago. I think the main problem is that the front bearings in the 4th gen F-bods, for example, are sealed units. So, unless one of the suppliers offers to supply the bearing hub as an assembled unit with the ceramic bearings, there isn't much chance of anyone using them. Maybe in the "older" cars, where the hubs and bearings weren't the sealed unit deal......
Old Jun 15, 2009 | 11:41 AM
badmfkr's Avatar
Default link of previous thread
I will contact the manufactor about the sealed unit he seams like a real slick Dude claims that cars that usalley made 250 on a tank of fuel made 300 w/ the ceramic wheel bearings
(my car gets 350 on expressway cruising a 16.5 gallon tank)
also increased 1/4 mile time by 1/2 a second.
do you have the link of previous thread?
Thanks
Old Jun 15, 2009 | 11:16 PM
Suaveat69's Avatar
https://ls1tech.com/forums/suspensio...-bearings.html
Old Jun 15, 2009 | 11:46 PM
SJM Manufacturing Inc's Avatar
Though lowering frictional losses may be seen based on their claims, ...For the typical oem hub automotive configuration, frictional losses I'd imagine are more substantial regarding typical OEM brake/caliper/pad design, not the bearings within the hubs. Frictional differences can be based to tire selection if you wanted to get critical.
You could change to a lighter wheel combination like our Bogart road race wheels which relates to better transfer of energy, more reactive handling, shorter braking distances, quicker response regarding suspension and better gas mileage. ...and it looks better than OEM too https://ls1tech.com/forums/wheels-ti...heel-sale.html.
Old Jun 16, 2009 | 12:11 AM
badmfkr's Avatar
Default rims
PHP Code:
[IMG]http://carphotos.cardomain.com/ride_images/1/2741/1141/6850570056_large.jpg[/IMG]
I have SSR gt-1 rims the weight is 17LBs compared to the OEM ws6 wheels at 25LBs, w/ powerstop rotors & pads.
was curious about the bearing claims.
Thanks
Old Jun 16, 2009 | 06:10 AM
leadfoot4's Avatar
Good point. Over the years, I've worked on a few cars where the road salt (here in the north east) has pretty well jammed up the pads within the calipers. I'm sure that the friction between the pad and rotor was pretty significant on those cars....
Old Feb 25, 2010 | 08:01 PM
phoenix's Avatar
i know i am bring back an old thread, but i am trying to figure what to do with my car. my front wheels do not spin freely. i have already rebuilt the calipers, so i am wounding if the hub bearing had something to do with it. If there is a hub bearing out there that will cause less resistance i would like to give it a try.
Old Feb 25, 2010 | 08:26 PM
EchoMirage's Avatar
through all of the road racing forums ive read, none of them have ever mentioned a ceramic hub. some of these people professionally race f-bodies, and road racing is WAY harder on hubs then any street or stab & steer racing. as it turns out, the best hubs to get are original, OEM GM hubs. none of the aftermarket ones are as good as GM. there is a person who made rebuildable hubs, but he wants $500 EACH HUB......$1000 for 2 hubs is just ridiculous.
Old Feb 25, 2010 | 09:06 PM
RAMPANT's Avatar
It is $750 each now.
Old Feb 26, 2010 | 07:39 AM
EchoMirage's Avatar
great, even better. nice to see he's taking in consideration the state of the economy........
Old Feb 28, 2010 | 08:36 AM
leadfoot4's Avatar
True, but he's probably getting beat up by his suppliers' increased pricing....due to the state of the economy!
