Clearcoat on aluminum rims???
Can you clearcoat a pollished aluminum rim like TT'2's, like they do stock WS6 rims?? And yes I do know about zoop seal!!!!
for the most part, any type of sealer i.e. clear-coating etc will dull and discolor over time. The overall luster will change which would not be desirable.You will find many factory aluminum rims coated due to the fact they are taking into consideration people will use them in everyday harsh conditions, i.e. winter, road salt etc...They‘re intent is being designed to be durable overtime while sacrificing final luster.
We do not coat Bogart rims for the same simple fact, a good coat of wax and occasional compound use is all the should be required to keep them looking like new...of course, if your using them in salt conditions, snow etc, then your definitely better off coating them... I personally wouldn't use any of the higher end rims in any poor driving conditions though...
hope this helps,
Steve
Yea that helps a bunch!!! thanks
I use zaino on my car and rims (stock rims) now and that works great
I guess when I get new rims i'll just keep up the good work allong with a little compound once or twice a month (no salt or much rain) Thanks again
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
