New wheels and tires need help with set up
I am buying new wheels and tires Monday morning. I am getting 15" weld dragstars for the front and 15" prostars for the rear. What backspacing to in need to make them work? Also need help picking the right size tire. I am puting in a 9" rear end. I am running true street so I need DOT tires.
Here are the rules
DOT slick tires or DOT legal radials tires required for drive tires during the road tour AND the True Street competition and class run off. Racing slicks prohibited. Maximum actual measured tire size is as follows: Actual measured tread of all racing slick-type tire is limited to 10.75-inches. For D.O.T. radial tires, maximum sidewall designation permitted is 325mm. Tire height is unrestricted. A “go-no go” gauge will be used to measured tire width. Tire shaving is prohibited. Tire changing is prohibited during or after the road tour.
Here are the rules
