GTO spare wheel for track use.
GTO spare wheels for track use.
I bought a set of GTO/Corvette spares to use on the front of my T/A(with new rubber). Are any of you guys using them on your LT-1 cars? It didn't seem like it wanted to mount up right. Do I need to machine the hub opening to make them fit up to the rotor tight? Thanks.
-SS
-SS
There was a thread on this like 2 days ago. A) They are so heavy they are not going to be much better off than your stockers, and B) GTOs use a diff lug pattern than F-bodys, so of course they are not going to fit.
If you want a skinny setup for the track, do it right. Using spare tires from a vehicle with a slightly diff bolt pattern is pretty trailer park.
-SS
I wasn't planning on using the tires, only the wheels. It has been done on here, for corvettes, and I've seen f-bodys too. The small amount of times I can go to the track don't justify a lot of money spent on new "track only setup rolling stock" Your car looks badass, is it driven daily on those wheels tires?
-SS
-SS
IMO the time spent mounting them to go to the track and back isn't worth it to save maybe a tenth if you're lucky.
And I like track times done in street trim. I want to know what my car will run as I drive it everyday, not what it'll run with lightweight track only wheels, slicks, etc.
