wheel studs not going on!
Old Jul 30, 2009 | 09:48 PM
johnLs1camaro's Avatar
Default wheel studs not going on!
well I broke a couple wheel studs on the front passenger side. Well I hammered them out and bought some new studs, and can not get them in! I first tried hammering them in, then I tried putting a open end lugnut on it and impacting it, still nothing. So then I tried the big daddy breaker bar, and ended up breaking the stud, but it still wasnt seated all the way.. Any ideas?
also I measured the width of the old and new, they look to be the same.
Old Jul 30, 2009 | 10:51 PM
01RedZ28's Avatar
The way did it was put some washers on the stud with an open ended lug and just wrench them on until they seat.
Old Jul 31, 2009 | 12:13 AM
EATSGTS's Avatar
where did you get the studs? call the parts store a verify the numbers of the ones you have.
Old Jul 31, 2009 | 12:29 AM
advance auto parts, yeah I will try that tomorrow thanks.
Old Jul 31, 2009 | 11:17 AM
fast93z28's Avatar
how did you break the studds ha
Old Jul 31, 2009 | 11:28 AM
01formula6's Avatar
I put a stack of about 8 washers over the stud, then an old lugnut and just pulled the stud through. This was with an 18V cordless impact so it doesn't have a ton of power. It helped to heat the area around the stud with a torch for about 15 sec first, without doing this my impact would not fully pull the stud through.
Old Jul 31, 2009 | 12:52 PM
Well I got pissed off and I have a totaled z28 that I used the engine and trans to swap in another car. I just took the hub off of it and put it on my car.. Problem solved! I got 5 lugs again!
