RPM 505 will this set fit?
2000 trans am
http://wheelstudio.com/catalog/produ...&staggered=yes
i only want an answer if you are 100% sure..
thanks..
thanks..
I'm running 275/35/18 all the way around, BS I believe is 38mm. The smaller BS means they stick out of the wheel well more so inner rub is no issue, I have Starno springs and have zero rub front or back.
