Got The Pro Stars On!
Old Nov 21, 2003 | 12:32 PM
EZMONEY's Avatar
Default Got The Pro Stars On!
Got some new pics of the Weld prostars on my car. Leme know what yall think.
15x10 rear with 7.5 backspacing and 5/16 spacer
15x3.5 front with no spacers and a shitload of grinding.
Old Nov 21, 2003 | 01:36 PM
Derek98z's Avatar
Looks great! I run Convo Pros. Love the big/little look
Here is a pic.
http://images.cardomain.com/member_i...19_25_full.jpg
Old Nov 21, 2003 | 01:41 PM
Black00Z's Avatar
Very nice.
How much is your car lowered? It looks good.
Old Nov 21, 2003 | 02:08 PM
EZMONEY's Avatar
Originally Posted by Black00Z
Very nice.
It has the Hal QA1 Adjustabel coilovers all the way around. Its lowered about 2 inches in the front and about 2.5 in the rear to get the *** end down on the 28" tires.
Old Nov 22, 2003 | 11:19 AM
Bad Blu Formula's Avatar
That car looks SWEET!
Old Nov 23, 2003 | 03:34 PM
The Guy in MY 99TA's Avatar
You said u used spacers on the back and ground the front calipers........
I thaught it was SAFER to use spacers on the front and GRIND the back b/c of the load applied when under accleration puts a pretty large load on the studs.
It looks good anyway! But I would put some stronger and longer studs on the rear!
Josh S.
Old Nov 24, 2003 | 08:09 AM
EZMONEY's Avatar
Josh S.
I alreadt have the longer ARP Studs in the rear. I had spacers on the front but to me it looks really gay when you use spacers in the front because the tires tend to stick out a little. I like all of my stuff tucked under nice thats why I didnt use spacers on the fron. Made it look a TON better IMO. The back without the spacer is tucked in to tight for my liking. So I used a spacer on it and it is just right with the rear wheelwell.
Old Nov 24, 2003 | 12:24 PM
RAMMAIR's Avatar
Nice wheels.
Old Nov 24, 2003 | 01:10 PM
PlainwhiteZ28's Avatar
so the 15x10s with a spacer fit the back with no grinding?
could i run a nitto DR on a rim like that?
and will the fronts fit with a spacer, no grinding?
or would it look really gay if i used an XP up front?
Old Nov 24, 2003 | 02:28 PM
MIGHTYMOUSE's Avatar
the rears need grinding either way.. just waay too much grinding without the spacer and just a regulaor (whole bunch) with the spacer
fronts dont need grinding at all with the spacer.
Old Nov 24, 2003 | 03:43 PM
SilverGhost's Avatar
Motorboater
Yes you can run a drag radial on Prostars. If you want to run a nitto you'll need 15X8 though, not 15X10..there are some big BFG dr's that will fit a 15X10 or like a Sportsman would work. The 275/60/15 Nitto on a 15X8 is a nice combo..
Old Nov 24, 2003 | 03:55 PM
SPANKY LS1's Avatar
Why, yes it is
Attached Thumbnails Got The Pro Stars On!-side-1.jpg   Got The Pro Stars On!-back-corner.jpg
Old Nov 24, 2003 | 04:03 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I have 15x10 rears, no spacers.
I have 15x3 fronts, with a spacer.. How much grinding was it, and where was the grinding? It does look crappy.
Old Nov 24, 2003 | 04:11 PM
SPANKY LS1's Avatar
After doing the rears first, the fronts are a piece of cake. Look at the calipers, there is a 90* "ridge" that has to be taken out and radiused....I think Tom the Roofer had some pics on his website of the fronts, thats what I used as a guide....
Old Nov 24, 2003 | 05:20 PM
5w20's Avatar
looks really nice
Old Nov 24, 2003 | 06:39 PM
gator's 99TA's Avatar
looks great, i LOVE how the rear sits! does the coil over allow for the car to be lowered? is this in conjunction with the lowering springs?
Old Nov 24, 2003 | 10:47 PM
Motorboater
well i'm kinda weird i guess, i like the way it looks with the fronts sticking out a bit..my fronts have spacers, but still a little bit of grinding.
i'd rather have them stick out than take material off the calipers that handle most of the stopping power..
Old Nov 24, 2003 | 11:13 PM
the fronts that you grind, you arent actually hurting the caliper itself. it doesnt mess with the application of how the brakes work. just shaving a thick part of the brake. otherwise no one would do it. ofcourse i just run a spacer and it works like a charm.
Old Dec 17, 2003 | 04:29 PM
Redlinez's Avatar
That black Z with Welds looks sweet (stupid). Are those wheels lighter than stock? My buddy swears by convo's, I just don't like the looks as much.
Old Dec 18, 2003 | 08:46 PM
Redlinez's Avatar
Do you have any other pics you could post up? Thanks.
