WTB lighter rims
I've been reading along about the different threads on lighter rims/street use/drag use.
I have the ZR-1's on my car now, all I am looking for is a set of rims that are a little lighter and look good for street use. I am not interested in the rims if they will not be as sturdy, durable, as a normal rim, so if that's the case I will probably keep what I have on the car. I have a set of drag lights for the car anyway for track use. Thanks!
Check out this thread:
https://ls1tech.com/forums/wheels-ti...rd-wheels.html
If you see something not listed, add it to the thread. Lance and I have been keeping the thread updated.
In general, chrome is heavy...powdercoat (paint) is lighter. I was able to drop 2 - 3 lbs. per wheel on my set up. 10 lbs. of unpsrung weight is quite a bit for little money.
Almost all so-called "custom" wheels are aluminum alloy. The real difference is whether (and how) they are cast or made from 1, 2, or 3 piece billet.
The coating is really the only difference, from polished, to painted/powdercoated, to chrome.
Service vehicles, like police cars and NASCAR vehicles, use steel because it is somewhat stronger, but more importantly, will bend. An aluminum wheel will crack, something you do not want if you are chasing someone and hit a pothole or jump a curb. Racing vehicles use steel because it will not catastrophically fail like aluminum will, but bend and deform.
One area that is hard to judge...tire weights. Sometimes, you can get the weight, but not usually. There is a few pounds in savings in using some tires vs. others.
If you are looking to spend money, the wheels Xsta listed are great options.
My 17x9.5 Fikse's weigh something like 17lbs a piece. But new cost around 1000 a piece.
