pro stars 15x8
Old Nov 27, 2003 | 03:29 AM
SuperSlowSSLS1's Avatar
Default pro stars 15x8
I just recently got a set of 15x8 pro stars
with a 26 x 15 - 10
I dont have any spacers what do I need to do in order for them to work on my car? What is the safest way to run them?? Spacers or no spacers?
I do have a Moser 12 bolt with extended studs..
with they work right now??
Please tell me what I schould do..
thank You
Frank
Old Nov 27, 2003 | 12:23 PM
Tally TransAm's Avatar
you probably have to grind the fizzuck outta the outside edge of the caliper and mounting bracket
thats what i had to do
Old Nov 27, 2003 | 12:34 PM
So there is no way that I can just take off my wheels and bolt these on...
How much do u grind it down?
What about runing spacers? Can I get some and just use those instead of having to grind down anything..
Old Nov 28, 2003 | 05:34 AM
AINT SKEERED's Avatar
They should work if you use a 5/16 spacer. I had som on my car that I borrowed from a freind and they worked for the track. If they were mine I would have grinded the calipers to make them fit right.
Old Nov 28, 2003 | 10:55 AM
How Exactly Do I Grind The Calipers??
How Far To I Grind Them Down?
Old Nov 28, 2003 | 05:31 PM
blkbeaZ28's Avatar
Put the wheel on and look through the spokes as you turn the wheel you will see where you need to grind. As far as how much everyone I read about or talk to says different things. Some say not much others say quite a bit. So I would grind and test untill you feel it is there or you can be like me and get you a set of Convo Pros.
Gilbert
Old Nov 28, 2003 | 05:33 PM
how much are convo pros?
Old Nov 28, 2003 | 05:44 PM
blkbeaZ28's Avatar
Wheels only from Jegs about $740 shipped to you in Houston at least thats what I remember from when I was looking. Wheels 172.99x2+139.99x2+lug nuts $25+spacers for fronts $15 plus shipping. You can find a semi used set with half life et streets and vw tires for about $800.
Gilbert
Old Nov 28, 2003 | 06:25 PM
I just want to find some 15 by 3.5 or 15 by 4
on tires
pro stars.. Used.. I dont have enough $$$ for new..
if any body is selling any PM ME..
I guess that iam just going to have to grind down the calipers.. I went today and got a set of spacers..
now i next my next step.. Is try to grind them down to get them to fit..
