Who makes a 17x11????
there are a ton of us that would be all over a 17x11 wheel besides the Zr1 replica. That is the ONLY one out there.... granted there are a couple variations, but that general style is the only one.
You can have just about any wheel widened if you want to pay for it. My car has 11" wide 00 WS.6 wheels on it.. Dont know if that helps any.
Id be down for a set of solid black C5 DD in 11" wide thats for SURE!!
yes, I have widened a set in the past however, if you are starting with a 48mm offset, and you add an inch, you end up with a ~73 mm offset since you are only adding to the inside. My 11s with a 50 mm offset barely fit with out rubbing with my 315 hoosier A6's on them. I don't think we have enough room to stick a widened rim with out needing the BFH to correct the clearance. Only good thing is that it would not stick out any further past the fender.
#33
#39
