wheel spacers ?
Old Sep 30, 2009 | 02:20 PM
AZ2ENVY's Avatar
Default wheel spacers ?
I'm looking for some wheel spacers in the sizes of 3/16's and 5mm . Where can
I find these at ? Thanks in advance
Old Sep 30, 2009 | 08:24 PM
DriftR's Avatar
I would think Summit would have them?
Old Sep 30, 2009 | 10:44 PM
Boo"SS"t's Avatar
Get the machined spacers (Baer or Jeg's brand), not the junk aluminum cast ones.
Old Oct 1, 2009 | 01:47 AM
69TA's Avatar
do they even come that small?
smallest I ever seen is 1/4"
Old Oct 1, 2009 | 05:27 PM
Posi's Avatar
Why are cast aluminum junk? Because they cost less? I love how people give advice without ever giving any reasoning behind it around here.
If you are talking about 1/2" or larger spacers that slip on over your existing lugs and provide their own extended lugs then I agree you should go with high quality CNC machined. Especially on the front of the vehicle. But the poster here seems to be looking for a small shim to change their offset slightly or provide backspacing. In that case Mr Gasket makes some that are 7/32" that will work just fine for their application.
Part #MRG-2370
Old Oct 1, 2009 | 05:34 PM
AZ2ENVY's Avatar
Thanks for the info Does Mr Gasket make 3/16's spacers ?
Old Oct 1, 2009 | 05:43 PM
Posi's Avatar
I don't think they make that size specifically. Your best bet is to just do a web search for "5 4.75 wheel spacer". There are several smaller companies and performance shops that machine their own so you may find a wider variety of sizes going that route. I know the use of spacers is a touchy subject around here but with the small sizes you are talking about I think you will be fine.
Old Oct 2, 2009 | 05:51 PM
AZ2ENVY's Avatar
If I go with the 7/32 spacer will I run into any issues like the lip of the wheel sticking
out past the fender , rubbing the spindles ? Or should I go with the 1/4" spacer ?
Old Oct 3, 2009 | 07:34 PM
sam90lx's Avatar
Let me know if you find any ZL1LT1 as I am going to be in need as well.
I will post if I find them also.
Old Oct 3, 2009 | 10:01 PM
AZ2ENVY's Avatar
I found some really nice 6061 machined 5x4.75 spacers 1/4" what size you lookin for ?
Old Oct 4, 2009 | 07:50 PM
sam90lx's Avatar
1/4" as well.
Where did you find them?
Old Oct 17, 2009 | 12:00 AM
sam90lx's Avatar
Hey ZL1LT1, how did the spacers work out?
Old Oct 17, 2009 | 01:19 AM
Engine_HP's Avatar
http://www.motorsport-tech.com/
for any one looking for wheels centric spacers/adapters
Old Oct 17, 2009 | 12:21 PM
sam90lx's Avatar
Thanks HP....they look good!
Old Oct 18, 2009 | 04:30 AM
Engine_HP's Avatar
will take some time to have them delivered here (to kuwait), ill let u know how the workout for me with some pics.
