18x10.5" 54mm offset .. Will 315's stick out?
Old 10-08-2009 | 03:32 AM
98 WS6's Avatar
Default 18x10.5" 54mm offset .. Will 315's stick out?
Like the title says.. if I run these wheels out back with 315's will they stick out a lot? Or should I go with a different tire?
Thanks guys
Old 10-08-2009 | 03:54 AM
hitmanws6's Avatar
they should sit further in, if you run a spacer they should sit relatively flush with the fender
Old 10-08-2009 | 04:49 AM
98 WS6's Avatar
I already have a 1/4" spacer and shank lugs sitting here in my room. I'm just afraid of the spacers because of all the stories I've heard with breaking the studs. Thanks for the response btw
Old 10-08-2009 | 09:19 AM
Xsta Z 28's Avatar
They will not stick out at all . . . may need a bit more BFH inner wheel well massaging with 315's . . . 295's would need minimal or none . .
Old 10-09-2009 | 01:27 AM
tspence45's Avatar
I'm running 335's on a 56mm offset, with a 5/16" spacer, and they don't stick out. So, you should be fine.
Quick Reply: 18x10.5" 54mm offset .. Will 315's stick out?
